Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › NostalgiTone Vibe + Dual Creator Combo compatibility
  • #34369
    Hello there,
    I am hoping to use the NostalgiTone Vibe single on a Dual Combo, and I noticed it came with a matching purple 3PDT wiring board. I also noticed that it’s mentioned on the page for the Vibe that the mainboard is a 4-layer PCB, so I wanted to check and make sure that there wasn’t anything also special about the purple 3PDT wiring board (other than it’s color), i.e. something that would make the mainboard incompatible with the Dual Combo Creator.
    Thank you for any help!
    #34370
    Since they both use 6-pin connectors there is no issue.
    The only one that doesn’t work with the combo creator is the Tremolo because it requires an 8-pin.
    #34371
    Awesome, thank you Barry!!
