Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › NostalgiTone Ascension Boost Single – inverted or regular phase?
  • #35470
    Jeff24
    Is the Ascension Boost Single PCB inverted phase? It’s not noted as inverted.
    I’m also seeing that none of the NT boost singles are inverted, even the Naga, which is based-on the Rangemaster (yet the PURP, also based-on the Rangemaster, is inverted).
    #35471
    All single transistor circuits are going to invert the phase. Though it only matters in a parallel or stereo rig.
    I have not been marking circuits as inverting or non-inverting for a very long time so just because it is not marked doesn’t mean anything. Nobody ever seemed that interested. If a circuit is actually marked one way or the other in the shop then it is correct.
    The NostalgiTone Ascension Boost uses a single transistor stage so it does invert the phase. Alternatively, the NostalgiTone Preamp Boost uses a non-inverting opamp so it does not. Also a reason to provide more than one type of Boost.
    You can peruse some common circuits already listed here: https://www.thegearpage.net/board/index.php?threads/list-the-pedals-that-invert-phase.796444/
    This is a Guide from our Guides Page:
    https://guitarpcb.com/wp-content/uploads/2018/08/PHASE-FOLLIES-A-Phase-Inversion-Guide.pdf
    #35473
    Jeff24
    Thank you. Very helpful.
