  • This topic has 1 reply, 1 voice, and was last updated 3 years ago by Anonymous.
  • #29353
    Dear build support guys,
    After several years of storage the Dr Phybes v2 from Musikding in the deep dark backyard of a closet I need help to get the phaser to run.
    Like I read in other threads my Dr doesn’t phase by itself. I re-soldered everything several times and checked if the matched set complies with the build manual. If the switch is on some areas of the tr1 change start to make noise and „plopp“ at one point.
    if the switch if off the turning of TR1 phases here and there the signal but don’t start itself oscillating.
    i tried to follow some of the hints but still it‘s not working. Please give me a hint because slowly I get nuts with the pedal.
    Thanks in advance!
    #29354
    Small addition to my previous post:
    I wired every ground I found to GND (blue wires).
    Red wire is supply voltage, Green input wires, Yellow output wires, Black wires for poti and switch.
