I don’t see any orders under your name through GuitarPCB.
Could you let me know how you obtained a Mule Kicker PCB so I can better assist you?
If it was purchased from another vendor (such as Das Musikding), you’ll need to contact them directly regarding the wiring boards and ribbon cables, as those should be supplied by the seller with the main PCB.
You need to contact uraltone and ask them to also send you the required wiring boards and ribbon cables that goes with the Mule Kicker. There should be (2) wiring boards and (2) ribbon cables that you need.
I am sure it was just an accidental oversight and they will take care of it.
Author
