  • #23004
    hi everybody,
    it was a long time!
    i’ve stand out a project from 2018, a civil war. Unfortunaly, it doesnt work yet. I’ve compare with my foxy lady which is good. So i’ve resolve 2 problems but it seems to be one or two more! i’ve read and read manuals, forums etc..
    bypass is clean, and when active, a low low volume without effect..
    So it’s a V3.0 with BC549C
    have u some remarque with the first picture please?
    thank u
    #23005
    in fact i ear that effect is working but the volume is very very low..
    any suggestions please?
    #23011
    I cannot trace the wiring with that photo alone.
    If it were me the first thing I would do is re-flow all solder joints on and off board. (about 15 minutes)
    Then I would re-check the Audio path wiring. You can also do this by doing a continuity check with your DMM and making sure every single point is covered with Ground and Audio wiring. From main board to jacks from main board to foot-switch.
    I would also trim the transistors and make sure they have a good mechanical connection.
    If all of that fails report transistor voltages.
    That is what I do for ever troubleshoot and yes we all have them from time to time.
    I hope that helps.
