  • #20628
    Hi guys,
    Havent required you help in a while up to my 14th build with usually no issues!
    My 1st ever build 2 yrs ago  was was Muff’n  green russian and it works perfectly so I have just built another one for a friend. During the build I accidentally used a A100K pot for Tone instead of B type but figured the audio taper would mean tone would change over smaller increment? No big deal, plus when you solder pots direct to the board they are a pig to remove.
    You may note I have soldered input to R1 as it snap during install and power in look like a short but is an illusion cause nothing work work if that was the case!
    I have the MId scoop B25k pot, Bender and clipping sw connected but they dont seem to influence the sound, reaching out to the wizards!!
    Thanks in advance
    Stu
    #20646
    So you’re getting effect Stu just low volume is that correct
    Could you post a pic so we can see all the offboard wiring to switches jacks etc
    #20647
    Hi Billy,
    I just noticed I built this off an old V3 build guide instead of the V3.5 one. the only difference I see is R27 on V3 board is 1K and V3.5 is 3K3, would this make a difference?
    Will post more Pic this afternoon
    Thanks Stu
    #20648
    Just noticed all R27 does is current limit for Leds correct?
    #20649
    No Stu that’s just the LED current limiting resistor
    What’s the rusty looking patch near D5 and 6
    Did you try reflowing the volume pot solder joints? the out tip solder joint looks a little dull too
    #20694
    Had transistors in backwards, was following silk screen but using BC549, All good
    Thanks Billy
    Stu
