Just checking to make sure I read the build docs correctly, if I stick a buff n blend on a Muff’n it is functionally an Animal with a blend control, correct?
By this is mean the Muff’n is the same circuit as the Animal minus the buffer section, correct?
Yes.
Also, the Muff’n does not invert the phase so you can use a Buff N Blend stock.
Author
