Hi all,
I first built a pedal. Just finished building a Mowah kit inside an old CryBaby. I love it. By the way, got rid of the heel click by arranging cables inside and using 2 tiny coaxial cables, getting their shields together as the 3rd signal.
The question. Using the pedal vs not doesn’t miss a lot of volume, just a bit, but the gain gets drastically reduced. I talk about the crunch, lead and ultra channels of a Hughes and Kettner Grandmeister 36. So there is a lot of gain. Crunch sounds like clean, and lead and ultra just a bit of distorsion.
I am not using the effects loop, I plug directly to the input.
Is it normal? Is it that the wah shall only be used with OD/distorsion pedals into a clean channel?
Thanks and take care.
