Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › MKC3 gain (old thread)
- This topic has 10 replies, 5 voices, and was last updated 5 years, 8 months ago by
August 1, 2018 at 11:06 am #1452
HelloI have built an MKC3 and have a problem: it responds in a peculiar way to the gain knob.
At very low settings it sounds very close to a BYOC Klon clone in a direct comparison. So having compared I also have realistic expectations for the max gain.
When increasing the gain nothing much happens until at very high settings, treble is attenuated.
The pedal is built without options and with the stereo pot for gain.
IC voltage readings. I do have a crappy voltmeter but hopefully it is sufficient for fault tracing purposes.
Source measured over “GND” and “+9V” on the PCB: 9,24V
Pin IC1 IC2
1 4,63 4,61
2 4,63 4,64
3 1,3 4,58 (both these readings seem suspicious)
4 0 0
5 4,53 4,59
6 4,63 4,64
7 4,67 4,67
8 9,25 9,26
I also tried swapping the ICs and got similar readings in IC1 socket after swapping
I enclose an image if that may help. I was a little confused with the pinning for the gain pot. Blue is pin 1 and orange is pin 3 for all pots.
Best regards. /Målberg
August 1, 2018 at 2:35 pm #1455
BarryKeymasterI would follow the usual troubleshooting ideas listed in the tips tricks and tutorials section of the forum which would include checking all values by code and verify orientation and re-flowing all solder joints. Since this is a complex build an audio probe may also prove useful to narrow down the list of suspects quickly.
Here is a proper breakdown of the correct voltages and audio path.
August 1, 2018 at 2:53 pm #1456Anonymous
InactiveThank you for the Swift response. I have double checked resistances, even though I have to admit that it is difficult to du unambiguously for the ones that have brown stripes at both ends.
I have also checked orientations.
I am a wee bit uncertain re capacitors. Perhaps someone could check the image for obvious errors?
Was I correct to wire pot pin 1 to 1 on the PCB?
I do not have or know how to use an audio probe so next step is re-soldering I guess.
Best regards /Målberg
August 1, 2018 at 3:49 pm #1458Anonymous
Guest+1 Barry. The voltage at pin 3 of IC1 is obviously too low. I suggest removing power and the ICs then resolder all joints. Particularly pay attention to pin 3 of the socket of IC1.
August 2, 2018 at 9:16 am #1467Anonymous
InactiveReflowed Soldier joints. No change.
I built a simple audio probe (internet is your friend). The readings are enclosed.
I noted each component following each signal path.
I measured on both sides on each component, where possible.
x means no signal
Check means signal. Where the signal was particularly weak I noted that with a comment.
All measurements were taken with effect on and all controls at 12:00.
C5 is not mounted so those measurements are taken at the empty terminals.
it seems that the area between R15 and IC2 is cause for concern.
August 2, 2018 at 1:55 pm #1469
BarryKeymasterIf you go to our Tips Tricks and Tutorials section of the forum and under Build Guides. (also available from the Home Page as a large green button) you will see a multitude of important guides listed in a row.
Here is the direct link: https://guitarpcb.com/forums/topic/pedal-building-guides-mandatory-reading/
Once there we have an Audio Probe Explained guide. This may be helpful depending on what you found on the internet.
August 2, 2018 at 2:51 pm #1470Anonymous
GuestFrom your measurements, it appears that you have bad connections from R15 through to R21. I suggest you remove power and both ICs. Then resolder all pads around R15, IC2 and R21.
Also, look closely to make sure there are no solder bridges that are causing shorts between traces on the board in those areas.
Also resolder all connections on the pots and their wires to the board. Resolder both sides of R3 and pin3 of IC1. Remeasure the voltage at pin 3 of IC1. It needs to be around 4.5V.
August 2, 2018 at 3:53 pm #1471Anonymous
InactiveThank you for your patience. I have successfully completed a few pedals before but fault tracing is not my forte. I had missed the audio probe guide. Will check that out, repeat the resoldering and, hopefully, get back with success.
January 14, 2019 at 1:20 pm #3781Anonymous
InactiveWhere you successfull? Did you have found the error? Was it the D2? I have also soldered the MKC and it doesn’t work. Maybe the installed D2 and R25 is the problem, because i use that with the 3DPT handy board.
January 14, 2019 at 1:31 pm #3782
BarryKeymaster@ Andreas
Many people do not respond once they have solved unfortunately. This thread is from August.
Please start your own thread with everything we need. Check voltages and report with your finding as well as photos. It only adds confusion when jumping on an old thread.
Your problem is likely a completely different issue and has nothing to do with D2 or wiring board.
February 28, 2021 at 7:05 pm #17376Anonymous
InactiveAhhh Barry my friend…. I’m not to good at this stuff but I was having trouble with my build as well and I realized that I should have followed the oration of the old schematic when it comes down to wiring the gain pots. when I take a good look at his photo I don’t think he would have been able to get the proper sound without fixing this first. I believe he had said he wired the pots 1:1, 2:2, and finally 3:3. he had stated that blue is always lug 1 and if we take a look at the dual/stereo pot the Lugs are not properly labeled. Can you please confirm my suspicion, and just curios is the 1:3, 2:2, and 3:1 the norm when it comes to gain pot/ or maybe are you similar with why some schematic are traced in this manner…..
Hello
