  • #11981
    Hi,
    i’m starting to build my new MKC pedal.
    I want to install the Ultra Drive Mod and ordered a DPDT On/On Switch.
    Couls someone please explain (or show where i can find it in the forum) what ist the best way to install the resistors to the switch an connect the switch to the board?
    I found a picture. Is this the best method to solder the resistors? And then wire the middle 2 pins to the R15 on the board?
    Thank you,
    Henrik
    #11983
    Yes Henrik
    wire your resistors as shown in your image and then  a wire from each R15 solder pad to the middle common switch lugs
    You can use a DPDT Toggle or footswitch or a 3PDT switch if you want LED indication of whether it’s in ultra gain mode or not
    #12037
    Thank you very much,
    Henrik
