Hello, I have just been finishing up 2 MKC PCBs, and I am having problems. There is no signal passing through the effect on either board. I am not getting a light on the LED, even. I used the GuitarPCB 3PDT wiring boards, which are new to me, but I carefully followed the instructions, and nothing is passing through the effect. I do get a clean signal. Before I go too deep, I wanted to check the wiring on the 3pdt board is correct, can someone look at my pictures and see if I am missing something dumb? I think I followed the proper directions! I am clipping a 9volt battery to the power and ground wire for testing, and I have 3 lead wires going to the LED, which is not lighting up at all. I am using the 3k3 CLR as indicated for R25. Please help! Thanks!
