Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › MKC: gain 2 (clean) is counter clockwise to increase?
  • This topic has 4 replies, 2 voices, and was last updated 4 years ago by Anonymous.
  • #26319
    Hi, I am doing 2-knob-gain MKC and with the gain 1 (dirty) at zero, the gain 2 (clean) increases counter clockwise. I can switch wires on the pot, but I wanted to check if that is expected behaviour?
    Another question: what should I socket to try adjust the bass boost switch? It is too much bass boost and I want to try tame it a bit.
    I just finished soldering and the first thing to fix is that I didn’t have 22K resistors in the power section for R23 and R24, and used 20K instead. Which I only now measured and they are both reading 19.2K.This is likely why my voltages are all at least 0.5v low, and the pedal sounds fizzy with 9v supply:
    3.9     4.0            IC2
    4.1     4.1
    4.1     4.3
    0        9.1
    3.8      4.1          IC1
    3.8      4.1
    3.1      4.2
    0         9.1
    #26320
    #26321
    Gutshots in prev post, some notes:
    The 820p, 390p, and 390n are all combinations of capacitors to get those values,
    also, the 1.5K and 15K resistors I didn’t have and used series combinations to get those values.
    For the ICs, TL072 sold out at my local store, used LM1458 instead.
    #26322
    Reduce the value of C5 to reduce the amount of bass boost.  I’m not sure about the GAIN 2 pot rotation.
    #26326
    Thanks for the tip on C5! I’ll socket that one and try some values to tune it to my taste.
