Built it this evening and I’m not clear what I should do here. The following was copied from build doc:
<div class=”page” title=”Page 1″>
<div class=”layoutArea”>
<div class=”column”>
*R12 has been included for those wishing to Mod the circuit with a Red (Hot) – BLUE (Normal) switch by placing a Jumper (Hot) on one side of a DPDT switch (or use one of our DPDT wiring boards) and a value between 47k – 100k for your BLUE tone on the other side. Then simply connect the switch to R12. Tip: Use a 3PDT switch to add an LED status to the Mod.
</div>
</div>
</div>
I was hoping to build a simple 3 knobber, and I interpreted this to mean I should simply omit R12. Circuit did not work. I threw a 1k in R12 and it started working, but sounded weird at the very low volume I am able to test at in my garage while still remaining married. What value should I use? I interpreted it as the jumper was only necessary when using the additional hot/cold switching. Just to be clear, I was hoping to make a very simple 3 knob pedal with no additional switching (I know, boring). Please advise. Thanks in advance.
