  • #16467
    I just completed the Killer B ee pedal – the gain structure is more aggressive than I like – anybody here have suggestions on how to make the gain behave more like an overdrive pedal than a distortion pedal. also – the tone knob doesn’t do much. Any experience with that out there? Thanks David
    #16468
    If you do not use the boost at the same time in series with the OD portion it is basically a Medium Gain OD as long as you do not turn everything up. The tone knob works fine for a basic passive tone control on mine. It is not a Tone TwEQ but it works as it should. If yours does not I might suggest posting some photos to see if there is a something wrong.
    For comparison:
