Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Hilfe bei Swah
- This topic has 10 replies, 2 voices, and was last updated 5 years, 9 months ago by
Billy.
January 29, 2021 at 5:24 am #16855
InactiveHallo
LED brennt und Bypass geht auch, auch Signal geht durch, aber leider ohne Effekt. Habe nochmal alles durchgemessen, und festgestellt,
das am Trimmer TR1 nichts durchgeht egal wie ich es verstelle. Desweiteren haben einige Widerstände nach einlöten andere Werte??
Für die Hilfe bedanke ich mich sehr. Der original C5 ging leider verloren, aber das Signal geht auch durch den “Alten” Kondesator.
Swah PDF Schaltplan geht nich zum hochladen?
Google Translate:
LED is on and bypass also works, signal also goes through, but unfortunately without any effect. I measured everything again and found that nothing goes through on the TR1 trimmer, no matter how I adjust it. Furthermore, some resistors have different values after soldering in? Thank you very much for your help. The original C5 was unfortunately lost, but the signal also goes through the “old” capacitor.Richard
January 29, 2021 at 11:19 am #16857Anonymous
InactiveNoch ein Nachtrag
Der Trimmer TR1 ist bei Pin1 und 2 mit 50k doch messbar. Hat der etwas mit dem Ampbias bei Pin 1 von LM13700 zu tun?
Viele Grüsse
Richard
January 29, 2021 at 12:37 pm #16860
BillyModeratorPost some images where we can see and trace the wiring to your DC jack, in and out jacks and 3PDT switch Richard
You wouldn’t be able to accurately measure resistances in circuit
Your Q1 and 2 voltages look off compared to the voltages listed below
I think you have IC3 in and out mixed up the out would be the pin with 5.5v
What are your voltages both sides of D3
IC2 all pins would be around half power except pins 4 power and 11 ground your pin 14 is a bit high so it’s just a case of finding out if this is where your problem begins it could be anything from a simple dry solder joint to a faulty component a few of your solder joints look dull and a few ball like which can be dry inside
You could reflow all those joints holding your iron on each for around 3 seconds until you get a nice flow and a good connection between component and solder pad
Be careful you don’t apply too much heat set your iron to around 400° Celsius and remove your ICs and transistors from their sockets
Unfortunately I’m at work on my phone and can’t zoom in to check everything but all your component values and orientation look correct
Working unit voltages
LM13700
1– 1.34 16– 1.34
2– 0.69 15– 0.69
3– 3.56 14– 3.56
4– 3.58 13– 3.57
5– 4.75 12– 4.78
6– 0.00 11– 7.22
7– 4.75 10– 4.78
8– 3.56 9– 3.57
Q1: (7.27 – 3.71 – 3.23 – DSG) Drain Source Gate
Q2: (5.05 – 3.75 – 2.90 – CBE)
Q3: (5.05 – 2.90 – 2.86 – CBE)
January 29, 2021 at 1:35 pm #16861Anonymous
January 29, 2021 at 1:37 pm #16862Anonymous
InactiveHi Billy
Many Thanks for your Help. My english is not so good. I am a old Guy with 66 Years.
Best Wishes from Bavaria in the south of Germany.
January 29, 2021 at 7:05 pm #16869
BillyModeratorIt’s very difficult to see and trace your wiring Richard do the white wires go from the main pcb white square in and out pads to the BI and BO pads on your 3PDT pcb
It may seem a bit of a daft question but do you have your guitar cable going to the IN jack and your amp cable going to the OUT jack
It’s easy enough to mix up your IN and OUT with the pcb the wrong way up and your IN on the left instead of the right
Not that it matters but I notice you have your stereo jack on the OUT side, but may have thrown you it normally being on the IN side
If you plugged your cables into the wrong jacks you would still get bypassed signal but no effect
A very common mistake beleive me I still do it!
January 30, 2021 at 8:01 am #16878Anonymous
InactiveHi Billy
D1=0,33v D2=0,33 D3=0,12 D4=0,8
IC2 nachgelötet Pin 14 jetzt 6,1v
IC3 nach Schaltplan richtig drin. Q2 Q3 wo die verschiedenen Base Ströme herkommen weiß ich nicht.
In – Out Buchsen sind verdreht. Habe schon 4 Pedale gebaut, und bei dem 3. erst gemerkt. Habe es so gelassen.
Ichweiß nicht mehr weiter.
Vielen Dank
January 30, 2021 at 8:04 am #16879Anonymous
InactiveIch vergas das Signal mit Audiosignalverfolger gemessen geht durch vom weißen In bis weissem Out.
January 30, 2021 at 9:27 am #16880
BillyModeratorGreat! you have an audio probe check if you get audio at pin 14, IC2.
With D3 it’s what voltage you get going in and coming out it does appear to be working correctly with what you have coming out of pin 14 IC2 and going into Q2 base dropping around 0.3v as expected
I think your problem may be around pin 14
January 30, 2021 at 12:23 pm #16885Anonymous
InactiveLieber Billy
Ich bin Amateur und Anfaenger, was soll ich machen, was kann ich machen?
Danke
January 30, 2021 at 12:54 pm #16886
BillyModeratorWhen you say audio signal tracker do you mean an audio probe to check for audio signal
I’m not sure what you mean by audio signal tracker
