Hello again,
I am having trouble with a sabotage pedal build. The effect works, but there is an ever-present oscillation. The oscillation is the same as you hear if you put an audio probe on the 9v power supply path. The oscillation is not present whilst playing a tasty lick, but returns when strings are muted. I have checked and rechecked. I reflowed solder and replaced the transistors. I checked all component values. I checked components with a multimeter before installing. Everything checked out. I purchased transistors through guitar pcb. They are socketed. My only suspects are possible bad electrolytic capacitors. I posted pictures of my build in an earlier post. Thank you for any advice you might give.
