Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Help please. Is it supposed to be like this? (Blues power V1)
  • #18363
    <hr />
    Unsure if im not supposed to install the trim pot or not in the blues power. Hole has solder in it. Wasnt my doing. </p>
    #18364
    The hole on the bottom looks as if it was untouched like the hole was just covered
    #18365
    Yes, remove the solder and install the trimmer normally.
    #18377
    As practice I would try to mount the Pot wiring flush to the board. You can still do that by standing the board and holding it on edge with one hand while simultaneously pushing the wire forward (with the same hand) and heating the backside of the pads with your iron. It should then slip through flush. Obviously take your time. As for solder droplets it is quite common for solder bits to fall off onto a board while working on a project. You wouldn’t hear it happening. One tiny bump and you have to clean it up. It happens to all of us all of the time.
