Is there an add on which would allow me to use a pedal for a headphone amp, or build my own? I’ve built 3 pedals from you so far – the zenith mini is my favourite.
Most effects pedals are designed to work into other pedals or into an amp. They are designed with low impedance outputs to drive into high impedance inputs.
A headphone amp is designed to drive a low impedance (@ 8 Ohm) load. At the present time, GPCB does not offer a headphone amp board.
Author
