Hello gang, I have an interesting one for you.
I made a G-02 Animal for a friend. He loved it. As of recently he claims that it has very low buffered output all of a sudden. It was fine but now it cuts the volume significantly when bypassed. When the pedal is on it sounds great.
I am picking it up tonight, but just wanted to get a head start on trying to diagnose this thing.
Since it worked and now it doesn’t, I am assuming I should check cold solder joints at the following locations, and the switch:
R1 to R8, C1 to C4, Q1, R38 & R39, R41 and C22.
Also, would a switch failure cause a low output? Or when switches fail do they just quit?
If I can’t figure it out I will post internal shots tonight.
Thanks in advance!
