• This topic has 2 replies, 2 voices, and was last updated 3 years ago by Anonymous.
  • #29368
    I tried adding a pot to starve the voltage on the pumped up fuzz face, but it’s not sounding the way it did when I used it with the circuit on my breadboard.  Someone told me starving it before the charge pump isn’t going to work that well.  Is there anyway I can go from a certain spot on the board to starve it?
    #29369
    Playsforfun
    Hey Marcus. I haven’t tried this but from I can see, following the guide above and the V5 schematic, you could insert the pot between C8 and the junction of R2/R3. I see only 2 ways of performing it. You could have a sister board attached in place of C8 as the cleanest way (my favorite) or cut the trace between C8 and R2 and solder wires to C8 leg and R2 leg (still effective). That is the only possibility that I see for insertion. Perhaps a keener eye or someone who has tried this can chime in. Cheers
    #29370
    Gotcha, thanks
