  • #23064
    Not really an effect pedal question…
    I was asked if i could build a footswitch for a friend’s Supro Delta King amp.  I looked online and it seems the one offered by Supro does not have any LED’s to show status.  These are dual latching switches and a TRS connection.  I built one similar for my AC15 (Tremelo and Reverb vs Boost and Drive on the Supro) but it has LEDs.  I am guessing that the internals on the Supro are not able to support the LED’s.  Is this a good assumption?
    Finally, if the above assumption is correct, my plan would be to use DPDT’s and a 9v battery to run the LED’s.  My friend would like the LEDs.  Is this the best / only solution for this?
    #23112
    Use 2PDT switches.  The extra pole can be used to control a status LED.  You can install a 9V battery and CLRs to power the LEDs.
