I want to wire a Boost circuit and Tube Screamer circuit in one box. I need to be able to select either A or B and Both A & B and bypass the signal. When selecting both, I need it to be one button, no tap dancing, and the same button to bypass. So, I guess I need to create loops?? Could the Paramix make this happen, all in one enclosure??
I have given your request some careful thought. Your requirements to select A, B, or both A&B as well as bypass them can be done by placing A and B in series within the effects loop of a Paramix. However, you would need to use more than one foot switch to select each of the effects as well as a bypass. I cannot visualize a way to do all of your requirements with a single switch.
