If you are trying to go for the “OG” sound of that circuit, 1n34a (if they are in fact legit), NOS 1n60p, and those USSR D series are all real good choices. I have found that in a K style circuit, taking the time to measure the fV on each diode, then trying to match two together that are extremely close in value will get you closer to the classic sound of this pedal than trying to go for a specific part.
I normally use the Soviet D9E in there, but only because they are inexpensive, plentiful, usually pretty close to the stock pedals fV, and normally have a tight tolerance spread making finding two matches ez.
Barry’s suggestion on using DPDT mod board is for sure the easiest way to A/B your selections. You could even have your preferred GE diodes on the board for position “A” and call is “stock”, then have some other interesting and unconventional diode option (asymmetrical Ge, Si diodes, LED, or some combination of those) on the other side “B” and call it “mod”
