Your Source for DIY Pedal PCBs and NostalgiTone! GuitarPCB Forum GuitarPCB Build Support EMEXAR 3 Micro Amp No Sound in effect mode.
Viewing 7 posts - 18 through 24 (of 24 total)
  • #19280
    My idea is if it worked and then did not work is you have an intermittent connection somewhere so recheck and reflow all off-board wiring as well as the components on the board.
    #19404
    Hey so I went ahead and reflowed my solder joints and no luck. Barry are you able to confirm the diode orientation for the board, also if I connected the MA correctly.
    #19408
    Check the voltage on pin 7.  You should be getting about 9V.
    #19413
    Well that’s the problem. My IC seems to not be getting power. It reads 0 at pin 7. Any guesses as to why the IC is not getting power?
    #19414
    Check all power and ground connections at the board and at the power jack.  Remove the IC and check for power at pin 7 on the socket.
    #19486
    I am only getting readings on pin 2,3, and 6. But none of the readings are above 1.0v. So I went ahead and resoldered the off board and on board. Still no luck… if I picked very hard on the low E string then I would get a quick dying amp sound, which was interesting but no luck still.
    #19487
    What are the voltages at the power jack, pin 7 with the IC installed, pin 7 with the IC removed?
