• This topic has 2 replies, 2 voices, and was last updated 4 years ago by Anonymous.
  • #26550
    I want to put a dsotm and a d’lay in the same box, creating a kind of Total Floyd effect.
    I’m planning on using Fuzzdog’s fuzzpup double up for the two 3pdt switches.
    I’m only planning on 3 setups:
    Dsotm;
    D’lay;
    Dsotm ->> d’lay.
    Anyone see any problems? I’m slightly nervous that the output from the dsotm will blow up the d’lay????‍????
    #26552
    The DSOTM output is not going to damage the D’lay whether in separate boxes or a single box.  The Fuzzpup Double Up looks kind of interesting.
    #26557
    Thanks for that.
    Yeah, the double 3pdt adapter has a lot of possibilities including the option to switch the board order – not relevant in my case….
