  • #3858
    The Dr Rock calls for a 2N5459 which apparently are nonexistent these days. What would be a close enough substitution? Would a J201 or MPF102 work as well as the 2N5459?
    #3860
    Always check Small Bear
    That said socket and try J113 and you can switch out if you like.
    I avoid MPF102 typically since like J201 there are so many bad ones. Unless you got them from me.
