Hi Max,
You could use a Buff N Blend to add a Blend however any Phase 90 circuit is going to be inverted so you cannot do that without adding an extra stage to the Buff N Blend loop in series with the Phybes so that the Phase is no longer inverting. A Stage 3 would be a good example.
You could build a Paramix which is an excellent tool to truly MIX wet and dry signals for any individual pedals you wish to insert in the loop and has a phase switch to instantly solve any issues.
You will not be able to change the Phybes to a Vibe with just a toggle switch.
