Your Source for DIY Pedal PCBs and NostalgiTone! GuitarPCB Forum GuitarPCB Build Support Colortone Overdriver – Treble and bass control don’t work
  • #26270
    Hello everybody,
    the pedal works, I like it a lot, it has a nice texture, it is silent. Everything would be perfect if high and low control worked.
    In the lower side of the pcb there is some insulating tape to avoid short circuit in the box.
    I am attaching photos to help you to help me solve this problem.
    Thanks everyone in advance
    #26271
    Allego anche lo schema
    #26272
    I know that I don’t have to solder the transistors directly on the pcb and that’s why I take the opportunity to check these values:
    #26278
    I would suggest that you carefully re-flow all of your solder joints both on-board and off-board.
    I see many suspect solder joints.
    #26286
    You’re right Barry, I went over the welds in suspicious spots and now the highs and lows work great.
    Thank you very much and have a nice weekend
