Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › General DIY Pedal Discussion › Clean boost/overdrive + Compressor all in one pedal
  • #19207
    Hello,
    I would like to create a compressor and overdrive pedal / clean boost.
    I would like to have 5 modes :
    • compressor only
    • overdrive /clean boost only
    • overdrive /clean boost in serie with the compressor
    • compressor in serie with overdrive /clean boost
    • overdrive /clean boost in parallel with the compressor with a blender to mix both signals.
    Do you think that s possible with existing PCB ?
    Thanks for your support.
    Have a good day.
    Ben.
    #19212
    You will need:
    separate 3PDT bypass switches for each effect.
    1 order switching board.
    1 Paramix to facilitate parallel mixing and blending.
    Complex wiring but it can be done.
    #19214
    Thank you  for your advices.
    I will check this solution.
