Your Source for DIY Pedal PCBs and NostalgiTone! GuitarPCB Forum General DIY Pedal Discussion Buffer interface with Silent Tuner Buffer and 3PDT buffer?
  • #18755
    Hello,
    Out of curiosity, would it be possible to build a buffer interface/router a la https://www.vertexeffects.com/diy-buffer-4cm-wet-dry using the Guitar PCB Silent Tuner Buffer Kit and an extra 3PDT Buffer kit? The basic idea behind this is that there are three correctly spec’d buffers in an enclosure – one you plug your guitar straight in to that drives the signal through your pedal chain, one that drives the signal from the end of your pedal chain to the front of the amp and one that drives the end of the pedals in the fx loop to the fx return of the amp. Would these two kits be enough to provide that?
    Thanks in advance!
    #18757
    If you wish to follow the wiring diagram for the device that is shown, you need three buffers,  I would suggest using three 3PDT buffers.  You can hard wire them without using foot switches and save a bunch of money too!
    #18759
    That’s a great idea, thanks! I was trying to integrate it into the silent tuner pcb so i could mute the output too at the push of a button – I suppose I could just add two extra 3PDT buffers to the enclosure I use at the same time?
    Thanks for the response!
