Hi. It could be if you make your own expression pedal to include the 100K pot required by the BnB. Or you can research compatibility if you want to use a store bought one of a certain brand. Then for your build, substitute the pot of the BnB with a TRS jack. Basically you are moving the balance pot to a separate enclosure to control it. If that all sounded easy, I’d love to see it posted when you finish. Cheers.
Author
