Hi everyone… I recently finished the Boogie 57 and on the test rig it works great. When I connect the jacks, foot switch, all I get is an oscillating rumble when foot switch is engaged. with foot switch disengaged, it passes clean guitar sound.
Thanks for the quick reply Barry, I will check them.. also, if you noticed the 10004 diode, I burnt one of the solder pads and relocated what I think is the correct alternative (it works ) do you see any problem?
