Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › Show Off Your Build › black dog problem
- This topic has 8 replies, 3 voices, and was last updated 5 years ago by
October 22, 2021 at 5:29 pm #21293
Inactivei have build black dog kit and i don’t understand why i have just a little sound, all controls seems working but i hear just a little sound and big breath when all pots are pushed to the max…….with little sound……sorry for my bad english, i hope you understand.
what do you mind about this ?
October 23, 2021 at 12:27 am #21295
BarryKeymasterPictures.
October 23, 2021 at 10:12 am #21301Anonymous
hi barry, nice to meet you !October 23, 2021 at 11:16 am #21303
BarryKeymasterBefore I begin looking this over in detail what do you have protecting the bare back of the metal Potentiometers from contacting the solder side of the board?
October 23, 2021 at 12:09 pm #21304Anonymous
Inactiveyes i have “bumpers” on the back of pots…….
October 25, 2021 at 2:54 am #21319
BarryKeymasterFirst I would make sure the transistors are seated good. Bend them a bit if you need. Make sure they are sitting tight in the sockets.
I know it might be hard to re-flow but try and reach as many solder joints as you can and re-heat them to make the solder flow again. You want to have some extra solder handy if you need to ad a bit more.
You can bend the pots up so you can reach more solder joints but be careful.
If none of that helps take some voltage readings of the transistors and report them here.
Example:
Q1
D = _.__
G = _.__
S = _.__
Q2
D = _.__
G = _.__
S = _.__
Q3
D = _.__
G = _.__
S = _.__
October 25, 2021 at 10:54 am #21325Anonymous
Inactivehi barry
i’m a king of soldering irons, i make perfect welding 🙂
but!!!!!
i have 2n5088 transistor !
and when i put this one instead one of the bs 170…… i have sound……just with light gain but strong, maybe the 2n5088 make less gain than a bs170 ?
seems this one of the bs 170 not works !
possible ?October 25, 2021 at 1:47 pm #21329Anonymous
GuestThe 2N5088 is a NPN transistor. This circuit uses MOSFETs. The 5088 will not bias properly in this circuit. Besides, the special tone of this circuit comes from the BS170!
Install BS170 and troubleshoot from there.
October 25, 2021 at 4:10 pm #21332Anonymous
Inactiveok,I’m gonna buy a bs 170 a musikding at my next order, I think the problem is this defective bs 170…..thanks for your support…..
thanks very much ! -
