I am new to building pedals I have had 5 successful builds. But I have also had about 5 fails I can’t figure out where I went wrong on this black dog build. I TESTED all my connections but I can’t seem to find the problem. I had the switch mounted to a breakout. That didn’t work! So I rewired switch directly added the clr and tried again to no avail. Led does not come on. I do get through signal but as soon as I hit the switch its dead. So now I am at a loss. I SET it aside for now. I will probably just work on another build. Here’s a pic of the enclosure I did for it. I will figure it hopefully.
I love that artwork.
I’m not a huge help on the troubleshooting, but the biggest thing is making sure everything’s the right polarity. Diodes, electrolytic capacitors, power supplies.
That last one gets a lot of people until it becomes muscle memory. Center post is negative.
Everything is test through my bench amp before and after it goes into the enclosure to avoid to much hassle, of taking it in and out to diagnose. Issues . Learned that the hard way.
