Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › APOLLO TREMOLO NO SOUND OUT (SOLVED)
- This topic has 27 replies, 5 voices, and was last updated 5 years, 3 months ago by
June 7, 2021 at 3:33 pm #19127
Inactivehallelujah!
I have sound !
the switch of sw2 was defective.
This during a new problem the circuit produces a high pitched sound even without playing the guitar. and the more I increase the gain the louder the sound.
June 7, 2021 at 4:22 pm #19129Anonymous
GuestOK. We get to start over on a new issue!
First. You have “sound”. Do you have the tremolo working? Do all controls function properly? Do they do what they are supposed to do?
Now, for the high pitched noise. It is likely oscillation in an opamp. Check to see if C2 is a correct value and is soldered properly. Check ALL ground connections on the board and to jacks.
June 7, 2021 at 5:13 pm #19132
BarryKeymaster
June 7, 2021 at 6:17 pm #19135Anonymous
Inactiveyes the tremolo works and the potentiometer too. and they do what they’re supposed to do.
speed ok, spacing ok, smooth ok, depth ok, gain ok.
C2 is correctly solder and Displays 3.06k.
All ground are connected.
June 7, 2021 at 8:16 pm #19136Anonymous
GuestIs the noise present if you disconnect the guitar cable from the effect? Is the effect powered by an external supply? Does the noise go away if you use a battery for power?
June 8, 2021 at 6:44 am #19146Anonymous
InactiveYes the noise is present when I unplug the guitar.
The effect is powered by an external power supply.
It does not work with a battery. I measure the battery and has 8.89v
June 8, 2021 at 12:57 pm #19155Anonymous
GuestDouble check your wiring for the battery clip. It appears that you do have one wired since there is a second power wire going to the power jack. The stereo IN jack acts like a switch for the ground to turn the power ON when a guitar cable is inserted.
I want to see if the noise is coming in from the external power supply. A battery will not produce noise.
June 11, 2021 at 6:25 am #19183Anonymous
InactiveIt took a long time to find a new battery. 😉
the system works quietly with the battery.what to do to stop having noise with the power supply?
June 11, 2021 at 9:22 am #19185Anonymous
GuestHey, that is great to hear!
June 11, 2021 at 12:23 pm #19187Anonymous
GuestNow that you have the pedal working properly on battery power, you need to consider purchasing a better external power supply.
Feel free to contact us again to assist with your next pedal build if needed.
June 11, 2021 at 3:06 pm #19190Anonymous
InactiveI tried with my 1 spot CS7 from truetone and the noise is still a bit there. weaker but still present.
