Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Aeon Overdrive no power (answered)
- This topic has 9 replies, 3 voices, and was last updated 7 years, 8 months ago by
Billy.
February 17, 2019 at 9:21 am #4295
InactiveJust built the Aeon Overdrive. Does not power up. Bypass mode works. Went over all my solder connections and wiring multiple times. I am obviously missing something. Checked everything from the power cord to each individual joint. Attached a couple of internal pics for you all to check. Any help is much appreciated.
February 17, 2019 at 10:40 am #4296
BillyModeratorCan’t see your DC jack clearly but main +9v should go to the outer power lug with the middle one being for battery power as I say can’t see if your power is going to the middle if so change to the outer one
February 17, 2019 at 10:43 am #4297Anonymous
InactiveIts to the outer.
February 17, 2019 at 10:51 am #4300
BillyModeratorDo you get 9v on the DC jack with the adaptor plugged in
February 17, 2019 at 10:57 am #4302Anonymous
InactiveI do not. Check cord and it shows 9volts but not behind the connector with the cord plugged in.
February 17, 2019 at 11:14 am #4303
BillyModeratorOK it’s difficult to see even when I zoom into the photo it looks like you have 2 red wires from the DC jack one to the main pcb +9v and the other to the 3PDT board +9v
If you have power going into the DC jack and not beyond then I’d reflow the solder joints on the DC jack I can’t see if any of the wires are touching I’m assuming not that’d be a dead short usually causing the wires to heat up so you’d definitely notice it! If you’re not getting power on the DC jack lugs make sure you’re using a centre negative adaptor and continuity check that ground is the centre pin on your DC jack
it does look like you have a lot of solder on the DC jack lugs so as I say reflow making sure you get a good flow and remove any excess solder sometimes even if it looks shiny on the outside with excess solder it can be dry on the inside making a bad connection
Continuity check from your DC jack lugs to the +9v pads making sure you have a good connection make sure its the lugs and pads you continuity check and not the ends of the wires same for your ground connection and conversely make sure nothings connecting that shouldn’t be
February 17, 2019 at 12:09 pm #4304
BillyModeratorSo just to recap and make sure I’m understanding correctly you’ve checked your adaptor (cord) which puts out +9v and when it’s plugged into the DC jack and you put your meter probes on the DC jack solder lugs you get no voltage? With your meter set to 20V DC
February 18, 2019 at 12:39 am #4313
MattParticipantDoes it work outside the enclosure?
February 19, 2019 at 8:13 am #4330Anonymous
InactiveGot back on it this morning and Billy your was right from the start. The power was on the wrong lug. Not sure if it makes a difference but I hadn’t installed the clr on the 3pdt borad either. You can never double check enough.
February 19, 2019 at 10:04 am #4331
BillyModeratorYou need the CLR on the 3PDT board with your LED mounted on it Smitty you may be lucky with the power not getting to the pcb and it might not have blown
Mount anything from around 1K to 4K7 depending on how bright you like it I’ve gone higher than 4K7 because I like them dull
Hopefully the DC jack is your only problem your build looks good to me
