  • #20298
    Hi, where should I wire the two leads of a 9V snap connector to the ADD VERB kit? The build document mentions the battery ground connects to the ring lug of the 1/4″ stereo jack (er, would that be the black wire of the snap connector?) but I’m not sure about the second connection–maybe one of the +9V pads on either PCB?
    I should note I’d like the versatility of either plug-in or battery power–I assume that’s a given.
    Can I also confirm wrt to the wiring diagram below and the stereo jack:
    • The white wire from the main board (IN) connects to the sleeve lug
    • The purple wire from the smaller board (I) connects to the tip lug
    I’m not using a Switcraft jack so everything looks a bit different!
    Thanks
    #20299
    To the Ring Lug of the Stereo Input Jack and the available Lug of the Power Jack.
