Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › General DIY Pedal Discussion › 7 Effects to Live Together in a Box, What Say You?…
Viewing 5 posts - 1 through 5 (of 5 total)
  • #25640
    e_man
    I had an old POD HD-300 give up the ghost a while back. Today I emptied all of the PCB’s from the case. As well as scavenging all of the 2 color LEDs, potentiometers, and switches that were on the PCB’s.
    The case is 18.5″ wide and would hold about 7 pedal enclosures worth of effects.  I like the idea of having an “all in one ” solution for jamming and gigging ala the Jam Pedals Pink Flow that would replace my pedal board.
    I was curious what the forum might think were essentials to have in a build like this.  I’m not necessarily referring to specific effects as much as categories of effects.  The Pink Flow has a compressor, an 808 style O.D., a triangle stye fuzz circuit, a chorus/vibe circuit, phaser “45” circuit, and a delay with tap tempo and quarter, eighth, and dotted eighths.  There’s also a “seagull” effect that I might be able to live without.  The Pink Flow is a cool setup, but I’m not necessarily trying to replicate it.
    I like the concept, and since I have the enclosure, I feel compelled.
    So, 7 effects to live together in a box…  What say you?
    #25641
    Guest
    I’m a believer in combos.
    #25643
    e_man
    Very inspirational!
    #25655
    Playsforfun
    Maybe not one box technically but these 7 worked out good for me.
    #25656
    e_man
    Very cool Playsforfun!
    Any kind of drive you might need with a tone tweq too!
    I’ve been considering one of the Tube Screaming Preamps.
    Thanks for sharing.
