I have a budget component tester that I purchased on the Zon.
I use it to determine and verify specs on transistors, JFETS and other components.
I occasionally get readings that don’t make sense to me.
The above photo shows the readings for a J201.
This photo shows the readings for another JFET (not a J201).
I’m confused by the readings. Does this indicate that the JFET is defective?
Have any of you had these kinds of reading show up when testing a transistor or JFET?
Thanks for any help you can give.
