  • #27603
    this project has been many moons in the making and finally buttoned up and sounds great.  what we have here is a dr frankenstein’s box of knobs and switches.  the Paramix is at the heart of it, giving me some mixing and looping options.  the wet channel has a built-in set of four effects + optional external loop and the optional loop for the dry channel is available too.  the wet channel signal path is MoRC compressor w/ pre post option -> Marsha overdrive -> optional external loop -> Mini-Me chorus.  from out of the Paramix, i’m going into the Ancestral Apparition reverb and finally out to amp or optional headphone out. i was real jazzed as this thing began coming together, almost in disbelief that i’d drilled the enclosure just right for almost everything to be board-mounted and rock solid.  thanks to all who contribute to this and other forums.
    #27605
    Steve
    These combo builds ALWAYS amaze me! It’s hard for me to keep 3 or 4 circuits sorted out in my brain much less a half dozen and more! Nice work!!!
