Your Source for DIY Pedal PCBs and NostalgiTone! GuitarPCB Forum GuitarPCB Build Support PCB testing before boxing with a Pedal PCB Auditorium Test Platform
  • #34722
    Hi.
    I’m building a GuitarPCB Vibe Single and I need to test it before boxing it.
    Is there a way to test it with a Pedal PCB Auditorium Test Platform?
    I’ve built a few through PedalPCB and use their Test Platform to test which works great, not sure exactly what to hook up with this one
    This is my first board from Guitar PCB, I have 4 other triple combos here waiting to be built but want to get this one working before proceeding with the harder ones.
    Help would really be appreciated
    Tiam
    #34724
    Yes it should be fine just connect your gpcb board snd, rtn, power and ground wires to it,  power it and plug your guitar and amp to the jacks as you normally would
    I’m not familiar with the auditorium but I’d assume it’s exactly the same as a test box so gpcb +9v and ground wires connect to + and – at the top of the auditorium and snd and rtn wires to the bottom screw terminal in and out you don’t need to bother with the auditorium LED ground and SW or the gpcb in and out which are the jack tips I think and the auditorium has the jacks onboard
    Looking at the schematic SND is the circuit input and RTN output
    #34728
    Thanks Billy.
    That worked perfectly!  Appreciated
    Tiam
    #34730
    I’m glad it worked Tiam
    Now you know it’ll work for any suppliers pcb simply connect in, out power and ground and off you go
