  • #23158
    e_man
    I’m building a T-Drive.  The only B500 pots I have are HUGE and they aren’t pcb mounted.
    To avoid the troubles I was wondering if an A500 might work.  I understand the sweep will be different, but will it change the tone of the circuit?
    It will be the gain control.
    #23160
    Increasing gain would be much more gradual using an A taper
    At 50% rotation a B500K would be about 250K where’as an A taper would be around 50K
    It would still work but may be bunched up in the last 10% with the pot being wired as a variable resistor
    You can see the difference in this diagram
    #23161
    e_man
    Thanks Billy.  I went ahead and put it together using the A500.
    It sounds good though.  The gain control doesn’t seem to be problematic so I’ll probably leave it.
    The pedal sounds good.  There just doesn’t seem to be much difference in the switch positions.  Don’t really hear the “hot” setting.  I saw something on the forum about someone else having this trouble.  I’ll change some resistors at R5 and see if it helps.
    Thanks for your help.
