  • #26216
    sofnwhat
    Ancestral Apparition and D’Lay with Tap Temp combination.  The tap board with all it’s fiddly bits was a daunting task and well worth the effort.  I also wanted a optional momentary switch for the delay for little echo’s and trail-offs in the middle of things.  I needed a way to mix two signals and even considered using a Buff-n-Blend.  alas, there were none in the cupboard but i had some blank perfboard and examples galore online. that takes are of the trailing part and the momentary footswitch labeled ‘Reflect’ fills the bill.  sloppy but effective, this was my first attempt to roll my own circuit.
    thanks to all the support and inspiration here and elsewhere.  you’re an awesome group of folks!
    #26218
    That is an awesome combo! Very useful.
    I am glad you took the extra time to put that together just the way you wanted it.
    Thanks for sharing.
    #26220
    Very nice. Excellent combo!
    #26221
    Chris
    Nicely done, this is excellent!  I’ve been thinking of a similar type build, so you may need to excuse some copycatting. 😉
    #26224
    sofnwhat
    Thanks, Chris.  I feel the same about your projects.  I should really upgrade my printer instead of beating myself up with the paint pens and stuff 😉
    #26232
    Steve
    Most excellent!! Don’t worry about the esthetics, like people, it’s whats on the inside that counts. 😉
    #34272
    Playsforfun
    Must have missed this one. Quite awesome!!
