  • #38354
    Roland Anderson
    I built a NT Dumble for a friend and he asked me about the function of the voice control. I’m not really sure what it controls. He says that in his mind it pans from a Bluebreaker sound to a more ODS sound. I didn’t play it enough to actually come up with that conclusion. What is your take on it?
    #38356
    It changes how the frequencies hit the clipping stage.
    It adjusts the low and low-mid content before distortion occurs. Because of that, it changes the character of the overdrive.
    Lower Voice settings:
    • Tighter low end
    • Smoother response
    • More focused mid character
    Higher Voice settings:
    • More low-mid content into the clipping
    • More open and articulate
    • More cut in the upper mids
    Since this control works inside the gain stage, it affects how the pedal distorts rather than acting like an EQ after the fact.
    #38362
    Chris Huss
    Does it also alter the bais of Q2?
    #38363
    No, it doesn’t change the bias of Q2.
