  • #30881
    peeeeeeej
    Hey there, is there an updated build doc for the D’lay Tap Tempo? It seems to still reference the v2 version of the D’lay board, and i’m a little lost as how to proceed (this post says “look at the old v2 doc,” but doing so hasn’t helped me figure this out).
    it seems like the best course of action is to:
    • install a 78L05 on the tap tempo board and connect it to one of the 9v pads on the 3PDT wiring board (v6)
    • connect the PT6 pad to the right pad of R22 on the d’lay v3 board.
    have i got this correct, or am i way off?
    Thanks!
    #30893
    I don’t have a physical pcb to continuity check so
    I’d install the 78L05 on the dlay pcb take your VB from the 78L05 output pin or C14 + side and jumper over to the tap tempo VB in pad
    You then want to jumper over to PT6 from the R22 pad that has continuity with R9 / time pot lugs 2 and 3
    #30902
    peeeeeeej
    following up; i was able to get continuity with the right (or top) pad of R22 on the d’lay v3, so it looks like my hunch was right, thanks!
