Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › General DIY Pedal Discussion › DI box, paramix ?
- This topic has 9 replies, 4 voices, and was last updated 5 years, 7 months ago by
March 21, 2020 at 11:30 am #11776
InactiveHi folks
first post here, I’ve asked mr billy knight about this and he directed me here so here goes.
Im a bass player and when gigging I like using a mic on front or the cab as well as the DI from the amp head, I’d like to do this but only by using one of the input channels on my bands mixing desk.
so I want to make a box that has
1 XLR Input from the amps DI
1 XLR input from the amps cab mic
1 XLR output to go to the bands desk.
I also want to add either 2 volume knobs 1 for the mic and 1 for the DI. OR a blend knob to control the ratio between both.billy suggested I might be able to use the Paramix PCB for this.
im not sure how best to go about it. Should I add ground lift switches and phase switches ect ? Other knobs ? Maybe a blend and master volume ect? Will the paramix work?
any wisdom from you folks would be much appreciated thank you
March 21, 2020 at 2:21 pm #11778Anonymous
GuestThe Paramix circuit uses unbalanced inputs. If you have balanced XLR signals coming from the amp DI and the mic, you would only use the non-inverted signal from pin 2 and the ground at pin 1 to send to the Paramix. SInce you are only sending these signals a short distance from the amp and mic to the enclosure, balanced XLR is typically not needed.
The Paramix has a separate level pot for each signal. This permits mixing the two signals in the ratio you desire.
The output of the Paramix is an unbalanced non-inverted signal. You would need to add a separate DI circuit (box) to change to a balanced signal with a XLR connection. If the distance to the band mixing board is not excessive, you probably don’t need to use balanced XLR for that line. Unbalanced 1/4″ plugs/jacks would suffice. I suggest you try using unbalanced first before buying an additional DI to create balanced XLR. Be careful to turn phantom power OFF at the mixers!
A ground lift switch is useful when running signals to a back of house board that has a separate mains supply. Sometimes this creates ground loops and hum. For an on-stage system, I doubt you would need it.
A phase switch simply reverses pins 2 and 3 in a XLR connection. Sometimes it is useful to help control feedback or to provide stereo imaging.
If you wish to build your own DI with balanced output, I can provide a schematic. I hope this helps.
March 22, 2020 at 9:25 am #11789Anonymous
InactiveHi wilkie
thanks a lot for the reply very informative. I think probably the paramix with a separate DI board is the way to go then
if you could send me a schematic that would be much appreciated! Thank you
March 22, 2020 at 9:32 am #11793Anonymous
InactivePs billy said that you would know the answer to this haha
March 22, 2020 at 11:13 am #11794
BillyModeratorAye did I not also say its a few bottles of the good stuff too?
I’ll come round and collect them for Wilkie no problem Dan
March 22, 2020 at 12:06 pm #11795Anonymous
GuestTack this on to the OUT of a Paramix. You can eliminate the VOL pot shown as a 2KJ. (That’s Barry’s 2Knob Job). I use those for a Solo switch. This circuit provides a balanced out to a XLR as well as 1/4″ Normal and inverted outs. You won’t need to buy a DI box. Save your money for the good Scotch whisky you’ll buy for Billy!
March 22, 2020 at 12:51 pm #11796
BillyModeratorHaha cheers Ray
I think once this madness is over young Dan should send u a wee flagon over
When he messaged me with the initial idea I think coz we talk pedals a lot he thought I’d know, sadly my answer was not got a clue!
Dan was getting desperate so I said don’t be desperate………Dan
Calm yourself down with a slice of cow pie and post it on the GPCB forums I told you to join ages ago and hopefully Wikie1 who I think will know how to do it will take pity on you like he does with me and give you some of his great advice and knowledge
March 22, 2020 at 1:22 pm #11797Anonymous
InactiveYou paint some picture billy ?. I’ll get yae a bottle of Irn bru and a Rangers scarf (couldn’t find toilet roll) ….final offer.
thanks a lot for the schematic Ray! I really appreciate it!.
March 22, 2020 at 4:46 pm #11802
BillyModeratorSeeing as you’re a Celtic bhoy Dan
I’ll overlook that comparison of toilet roll and one of the mighty Glasgow Rangers scarfs on this occasion only, but with all this panic buying madness I’ll take the toilet roll mate
And seeing as you’re probably taller than desperate Dan in real life I’ll expect a fairly large one
March 24, 2020 at 5:09 pm #11861
BarryKeymasterLet us know how your project turns out.
