Your Source for DIY Pedal PCBs and NostalgiTone! GuitarPCB Forum General DIY Pedal Discussion Could a 2 Knob Job be used to create a channel switching setup?
  • #25547
    e_man
    I want to be able to switch between 2 effects boards.
    I’ve built one using a board from another supplier that was an effects loop switcher.
    It seems like I read somewhere on here that someone used a 2KJ to accomplish the same thing.
    If not a 2KJ perhaps something else.  I could probably wire up a 4PDT (I want status LEDs) without a PCB, but a board would make it simpler (I think).
    Thanks for any guidance.
    #25548
    Any of Barry’s 3PDT boards can be used to switch between 2 channels.
    Use lug 2 as the IN.  Lug 1 sends to channel 1.  Lug 7 returns from channel 1.
    Lug 3 sends to channel 2.  Lug 9 returns from channel 2.
    Lug 8 is the OUT.  Not used if you need separate OUTS from lugs 7 and 9.
    Lugs 4,5, and 6 provide LED status.
    #25558
    e_man
    Thanks wilkie1!
    Had a “Duhhh” moment when I first saw your response.
    Do you think there would be a need to ground the “off” channel to prevent popping or noise?
    Thanks again for your help.
    #25565
    That might be needed.  Try it and see.
    #25569
    e_man
    the 3PDT GPCB board I have has lugs 7 & 9 tied together with no solder pad tied to them.
    I don’t think that’s going to work for me.  I need 7 & 9 for the second effects send and return.
    Think I’m gonna have to skip the PCB.
    #25576
    I think you are looking at the 3PDT wiring board numbering differently from the way we use it.
    Read my suggestion above using this diagram.
    #25577
    e_man
    Forgive me wilkie1, I shouldn’t have typed lugs 7 & 9, should have typed 3 & 9.
    On the pcb I have. lugs 3 & 9 are tied together and I didn’t find a solder pad that was connected to them.
    Sorry for the confusion.
    Thanks.
