Your Source for DIY Pedal PCBs and NostalgiTone! GuitarPCB Forum GuitarPCB Build Support Can the boost on my Super Drive 70’s Combo be attenuated?
  • #29022
    e_man
    Even at it’s minimum setting the boost is too loud.
    Comparing the schematic, I don’t see the resistor that is referenced in the Stage 3 build docs to adjust for attenuation.
    Anybody got a suggestion or a hack?
    Thanks.
    #29028
    The resistor added to the newer version only keeps your volume from dipping too low even at Mid rotation. It will not help if you are already too loud at minimum rotation.
    If yours is too loud at minimum rotation I would suggest you have an issue.
    First, what is your bias voltage?
    Verify the Volume pot is not wired backward.
    If that’s not it then verify all of the resistors.
    I have built so many of these and (volume too loud) has never once been my experience, especially at minimum rotation.
    #29029
    e_man
    Thanks Barry, I’ll check my resistor values.
    I think the pot is wired right because it gets louder as it’s turned clockwise.
    I had my voltage around 5 volts (whatever the build doc instructed).
    But I’ll give another check this weekend.
    Thanks for your help.
