Home Forums General DIY Pedal Discussion 18v power options
  • This topic has 2 replies, 2 voices, and was last updated 1 month ago by brd.
Viewing 3 posts - 1 through 3 (of 3 total)
  • #14257
    brd
    I have built an Over Drive Circuit pedal that is ready for 18v and I’m trying to decide if I should buy an 18v power supply or use a charge pump.
    Are there any issues or concerns with using a charge pump to power that circuit at 18v that would make using an 18v power supply a better option?
    #14371
    wilkie1
    An isolated power supply would provide a quieter voltage to the pedal than a charge pump.  If you use a charge pump, be sure to follow the recommended filter capacitor  values.  You want to do two things:  Filter high frequency noise from the oscillator and provide reserve charge to prevent voltage sag under load.
    #14399
    brd
    Thanks, that is very helpful Wilkie, There are a couple pedals I want to try this on and I have some extra 1044’s to breadboard a quick test circuit. If it works, I’ll try to build it.
