  • #32488
    In the Documents for the Sriracha Fuz 2022, the Bill of Materials calls for a 3k3 resistor in R14.
    But on the schematic it calls for a 1k8 resistor in R14.
    Which is correct?
    #32489
    R14 is the LED current limiting resistor in the older docs it was usually 1K8 for a pretty bright LED
    Both values are starting points I’d personally consider 3K3 too bright,  for a standard LED I’ll use 10K
    So it’s a personal preference depending on how bright you want your LED
